Use this procedure to view port EAPoL operation statistics.
Use the clear-stats command to clear EAP/NEAP statistics.
Switch:1(config)#show eapol status interface ============================================================================= Eap Oper Status ============================================================================= PORT MAC STATE VLAN PRI Flex-UNI I-SID VLAN:I-SID NUM ID Enable SOURCE AUTH ----------------------------------------------------------------------------- 1/1 18:a9:05:b1:04:ce authenticated 10 2 true radius 0:1015 ----------------------------------------------------------------------------- Total Number of EAP Sessions: 1
Switch:1(config-if)#show eapol status interface gigabitEthernet 2/1,2/2 verbose ===================================================================================================== Eap Oper Status Verbose ===================================================================================================== PORT MAC PAE VLAN PRI Flex-UNI I-SID VLAN:I-SID ACL ACEs NUM STATUS ID Enable SOURCE ----------------------------------------------------------------------------------------------------- 2/1 00:00:02:eb:34:e9 authenticated N/A 0 true radius 111:10111 2 2,3 2/1 00:00:02:eb:34:eb authenticated N/A 0 true radius 111:10111 2 1 2/1 00:00:02:eb:34:ed authenticated 333 0 true n/a 2 4 2/1 00:00:02:eb:34:ef authenticated 444 0 true n/a 2 5 2/2 00:00:00:06:a9:df authenticated 11 0 true n/a 1 1 2/2 00:00:00:06:a9:e1 authenticated N/A 0 true radius 111:10111 2/2 00:00:00:06:a9:e3 authenticated 33 0 true n/a 1 2 2/2 00:00:00:06:a9:e5 authenticated 44 0 true n/a 1 3 ----------------------------------------------------------------------------------------------------- Total Number of EAP sessions : 8
Use the data in the following table to use the show eapol status command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
<1-4059> |
Specifies the VLAN ID for which to show the statistics. |
verbose |
Displays detailed statistics information. |
